chasingsunshine
- Joined
- Jul 7, 2017
- Posts
- 24
Hi everyone, Below is our listing for our short bus conversion, please note the bus in located Southern Ontario Canada. we are asking $22,000cad (aprox-17,000usd)
1997 ford B800 school bus conversion for sale, This legally converted RV Title (Ontario) skoolie conversion is a one of a kind build on a full sized bus frame but only 24’ long and easy to drive, Strong running 5.9 Cummins Diesel engine with a 5 speed manual eaton fuller transmission, the conversion is 90% complete and awaiting final personalized touches. Perfect for a full time rig or for just a weekend getaway. Very little rust and runs very well, was used as a full time rig with no issues for 6+ months but unfortunately plans changed. Please see the full list everything completed/installed below, please email for any further questions.
Vehicle Specs
- 1997 Ford B800
- 5.9 Cummins Turbo Diesel Engine
- Thomas Build Body
- 5 Speed Eaton Fuller Manual Transmission
- Hydraulic Brakes
- GVWR 10,432kg (22,999lb) Note this is just under the heavy licence class (24,000lb+) anybody holding a standard Ontario “G” Class License can drive it
- Legally Converted To RV title in Ontario
- 412,470kms (256,296miles)
- 1,466 hours
- Passed Ontario Safety and Emissions testing in November of 2018
- Rear Tires (dually) 295/75 R22.5 (201
- Front Tires 9R22.5 (2014)
- All Wheels are “Daytons” (Ring and Clamp style attachment)
- Vehicle Was Purchased in British Columbia brought over and Registered in Ontario (2017)
- Custom Passenger Seat Belt Professionally installed
- Heavy duty Trailer Hitch Installed (not wired)
- Completely re-insulated floor to ceiling with rockwool.
- Lightweight materials used throughout keeping total weight down.
- All windows have been resealed
- Roof painted with Coolflex roof coating
- Exterior is sprayed on Napa auto paint
- Interior Led Pot lights
- Ceiling is Tongue and groove pine (painted white)
- Vinyl plank flooring
- Custom fold down dining table/couch/passenger seat set up
- Bathroom (compost toilet room) has sound insulation and a solid wood door
- Elevated bed (mattress included memory foam double size) with access to storage underneath
- Butcher Block Countertops
Technology
- 4 - 6Volt DC FullRiver Batteries Sealed AMG (dc224-6)
- AIMS Power 1000W 12V Pure Sine Inverter/Charger UL Listed. (PICOGLF10W12V120V) With 120v Exterior plug/connector for campsite hook up
- 400 Watts (4x100W) of 12v Renogy Solar Panels with 40amp Renogy Rover Mppt Charge Controller.
- Blue Sea Systems 12 Circuit - DC-12v Fuse Panel
- Fan-Tastic Vent RV Roof Vent with Thermostat and Rain Sensor With Remote (Model 7350 - White)
- WeBoost Drive 4G-X RV (470410) Cell Phone Signal Booster
Mechanical Work
- Engine Dowel Pin Fix kit installed KDP (avoids the dowel pin coming loose - common issue on the 5.9 cummins) 2018
- New Front Cover Seal 2018
- New Oil Pan Seal 2018
- New Fuel Rail 2017
- New Throttle Body Return Spring 2017
- New Steady Bearing 2017
- New Rims and Tires on Rear (dually) Cooper RoadMaster 295/75 R22.5 - 2018
- New Driver's Side Windshield 2018
- New Starter Motor 2019
- New Air Seat (out of a 2013 Volvo Truck) under-mount Air Tank and compressor (with quick connector for air tools) 2018
- New Wheel Hub Oil Cap and Screen Front Drivers side 2018
- Transmission (FS4205A) Full Rebuild Including bearings, synchronizers and input shaft. Oct 2014
- New Led Headlights
- Brand New Grote West Coast Style Mirrors with led marker lights and 8” Blind Spot Mirrors (All 4 Heated)
- Brand New Led Roof Marker Lights
Accessories
- Dometic CFX75DZW 12v dc/ac Electric Powered Cooler, Fridge Freezer 2.5 cu ft. |74 quarts | 70 Liter
- CB Radio - Cobra 18 WX ST II and Astatic SWR-Meter - Single Antenna Wilson Mirror mount with Firestick Rod
- 2 36” Buyers Truck boxes custom mounted on body of bus (with built in locks)
- Air Head Composting Toilet with extra fluid tank - Solids tank never used but vent is hooked up.
- Dometic origo 3000 Dual Burner Alcohol Stove
- 2 5Gallon Water Tanks Fresh/Grey - Sink Drains into Grey - Fresh water pump not installed but included.
- Exterior Led Flood Light
- Tablet Dash Mount
Included but Not Installed
- Victron BMV-712 Battery Monitor
- RecPro 42 Gallon RV Water Tank 39” x 18” x 14”
- Cubic Mini Grizzly wood Stove - Includes flue pipe, Wall Mount, Flue Cap, Silicon Gasket, and Fire tools and heat fan.
- Water Pump Pentair Shurflo Revolution 4008
- Water exterior hook up panel
- Water hose and filter
- Waste Rhino hose and connectors
- Water tank level monitor (KIB micro) and nodes
- Lots of extras including brake controller, extra led pot lights, hinges, extra brake lights, door for solar cabinet, and various hardware.
Work left to complete
- Finish Trim-work throughout
- Flooring around driver's seat
- Entrance Stairs
- Wood stove pipe installation
- Water pump/Water lines
- Ready to be customized to your own personal taste!
- Conversion photos available upon request
Vehicle Specs
- 1997 Ford B800
- Thomas Build Body
- Hydraulic Brakes
- 1,466 hours
Technology
Mechanical Work
Accessories
- Tablet Dash Mount
- Entrance Stairs
