bansil
welcome
91 Bus Guy said:Jeremy, just a quick question. The switch on the door opener, what does it do? I thought it was to turn on a step lamp or maybe to start the flashers out back working. I can't see it doing anything.
Thanks,
Keith
I don't have any overhead warning lights. This was never a school bus, it was a old folks home transportation bus. I see a place that the lights would have been, but none ever existed.want2camp said:91 Bus Guy said:Jeremy, just a quick question. The switch on the door opener, what does it do? I thought it was to turn on a step lamp or maybe to start the flashers out back working. I can't see it doing anything.
Thanks,
Keith
If you have a manually operated door and the switch you are referring to is a momentary contact switch that is depressed by the door lever it should be to activate the overhead warning lights. Maybe yours were disabled at some point.
Good thought, and thank you. I have a note to that effect and may do that.richlindquist said:That switch could be attached to a "door not latched" indicator. If it isn't, it might be a good idea.![]()
Rich
