So I'm trying to start making serious progress on my 'shorty' 1991 TC2000 w/ 12v 5.9 cummins. Got it home on the concrete driveway, been crawling all over the thing. Found lots of really nasty looking hoses and seals all over the engine. Heater hoses with bubbles all the way down them, trans cooling lines are rusty and crumbling, the big tappet cover plate gasket is deeply cracked all around, there's oil everywhere... and really I'd like to do some mild mods to the injector pump that cant be done while it's in frame, replace the OVF, make sure the lift pump is good, and other maintenance... and with this thing in the floor it just feels like none of that is really possible. On top of it all, the AT545 is getting swapped with a Allison 2500, so we might as well pull the whole thing right?
How the **** do you get it out? I see the two big lift points on top of the engine, but it doesnt look like there's really room to get my engine crane between the top of the engine and the bottom of the cowling to pull it out the front. Anyone here done it before?
