98/99 Blue Bird / 8.3 ISC CAPS / Injector Issues
CHEESE_WAGON
Traveling
Sep 2, 2013
2,302
Virginia
As some may know, I offered and agreed to transport Manidinee's recent purchase of a 40-ft Blue Bird RE (98 or 99 model), equipped with Cummins CAPS-equipped 8.3 and Allison MD3060.
The bus has developed some running problems a little over halfway into the trip after running well for well over 1000 miles, and after making arrangements to get the bus looked at, Mandinee has persuaded me to post here seeking opinions on the matter.
After leaving a hotel near the I-79/I-80 junction (just before getting into the tougher hills of PA on I-80), I started noticing a sound sort of like machine gun fire when the engine dropped to 1500 rpm. I assumed the engine was lugging and needed a lower gear, so I manually downshifted the trans and all was well.
I assumed the engine was lugging, but was curious why the transmission was not automatically downshifting as an automatic should do under that condition. Other than that, the bus seemed to be lacking a little power on hills, but not overly so, and otherwise appeared to be running fine. No warning lights, oil pressure, temp, all were looking good.
When I made a pit stop a while later in Drums, PA, the engine had a noticeable lope when it came to a stop and was noticeably louder as well. Turns out the flex hose between what I assume to be the turbo down pipe and the muffler had broken.
The only shop in the immediate area that would look at it charged the owner four hours labor for what wound up being two hours work, and fixed only the exhaust, not addressing the lope, which was obvious. Idiots. Sherwood Freightliner Drums, PA - to be avoided. It's clear to me they didn't really want to deal with this thing.
I found another shop about nine miles away and proceeded there. Interesting note here. The bus was billowing white smoke getting onto the highway, but cleared up when I downshifted the trans to fourth gear, which got the rpm up around 2100. At that point, the bus seemed happy and I could not tell whether it was continuing to smoke or not. I know that black smoke indicates too much fuel, and white smoke indicates insufficient or no fuel, so why would white smoke clear up at higher rpm?
The shop tinkered with some of the injectors and found one leaking (oil, I think, as it has been throwing a small amount of black residue out the rear of the bus), another one loose, which they said had backed off two turns. These two injectors, in question, are the two directly adjacent to the bellhousing end of the engine. I'm thinking the residue that I had thought could be from the pinion seal could very well have been from this injector leaking, which means this bus spent a lot of time idling and possibly more time reversing than forward.
What's curious here is that I watched and listened as they tested each injector by cracking it open and re-tightening to see how it affected the engine. The engine developed the same misfire each time. The white smoke, however, did not go away when the misfire was corrected.
It is now my opinion that the sound I heard like machine-gun fire could very well have been a cylinder misfire, but unfortunately it was dark and I could not see if the engine was smoking. It was a reasonable assumption that the engine was simply lugging at that point, as there seemed to be no other obvious conclusion. Above 1500 rpm, the bus seemed to run fine. If I had noticed any problems after downshifting the trans, I would have stopped to verify what was going on.
With CAPS putting a computer in the loop of fuel control, however, I couldn't be sure how much further the bus was going to make it under its own power and whether it could make it to another shop under its own power. Not wanting to make Mandinee and her husband pay for a tow bill if it wasn't necessary, I recommended she make arrangements for an on-site Cummins tech to give a more specific diagnosis and determine whether a shop visit is needed. Hopefully if it is just injectors, that can be done on-site without a tow bill. Or, if a shop is required and it is just injectors, that can be done by the shop it is currently parked at.
I'm just curious because the symptoms are very confusing. Clearing up and running better as RPM rises would suggest overfueling, which would be black smoke. There was black smoke initially when the exhaust was broken open. Since then it has been white smoke, however, and it seems to me white smoke should get worse as RPM climbs.
Also, it almost appears to be sporadic in that it does not go away at idle regardless of misfire, gets extreme on low-speed acceleration, but clears up above 1500 rpm at speed. Granted, I am not a diesel mechanic by trade, but it does not make sense to me at all. Seems me overfueling would clear up with RPM rise, which would be black smoke. Seems to me a no-fuel misfire would get worse and worse as RPM rose.
In a nutshell, it blows white smoke from idle to about 1500 rpm, possibly more, especially on acceleration, has a chattering noise in mid-range RPM, and clears up at 1800-2100 rpm cruising, running fine with little to no smoke. After researching a bit about the operation of the CAPS system, I'm leaning toward the air bleeder or pressure control valves in the CAPS pump, but there are obvious issues with at least two injectors, as I am not convinced this is the first time that the loose injector has backed off.
Has anyone else seen this before with a CAPS system, and if so, what was the problem? Also, is the CAPS system technically an HEUI system? It certainly seems like it, though I thought these didn't show up until the mid-2000s.
Side note: Once this issue is resolved, along with a couple other things I feel need work, I think Mandinee has made a decent purchase. This bus drives fairly well, but seems to have a bit of play in the steering. I am curious if REs tend to wander more on bumps due to not having the weight of the engine in the front, and whether this could exacerbate play in the steering gear box or linkage?
If you are having fuel issues don't drive the bus. The ISC uses an electric pump to prime the mechanical lift pump. If the fuel filters are restricted or their is a leak letting air into the system the high pressure pump could be starved of fuel, over heat and die. If the CAPs is toast replace the filters and the suction fuel line.
The fix to prevent CAPs failure is to install a electric fuel pump that is on with ignition at the fuel tank. Pushing 10 psi to the CAPs ensures it has fuel and pushes a little extra through for added cooling. This is discussed in detail on a couple RV forums.
Good luck
Ted
FASS makes an excellent pump that goes right where the fuel filter screws in. It's expensive ($600) but still way cheaper than a new CAPS. Like Tjones says, it eliminates another point of failure and ensures that the CAPS gets a steady flow of good fuel.
I'd love to install a fuel pressure gauge in my bus for peace of mind but running over 40 ft of wiring isn't much fun at all.
I'm planning on adding a Davco water separating filter right at the fuel tank with FASS pulling fuel through it. I think their pump with the correct pressure range was around $380. They are more expensive if you get their pump and filter set up. I'm going to add a fuel pressure sender at the fuel inlet to the CAPs and run the wiring with the wiring harness in the bus body when I do a little wiring harness clean up.
Ted
Lope is likely a misfire, caused by a bad injector or o-rings. With what you're saying about white smoke, misfires, and running rough, I'd say you almost certainly have a bad injector. It seems to go away at higher rpm because the higher speed masks the dead spot.
White smoke could be oil, coolant, or fuel vapor. I'm thinking yours is fuel dribbling out of a bad injector on the exhaust stroke.
You should get it fixed asap. Hopefully you didn't ruin anything as is.
Listen to the other guys on fuel system upgrades, cummins really dropped the ball on fuel system reliability with the first versions of the ISB/ISC
The caps system isn't a heui system because it doesn't have hydraulically actuated electronic unit injectors, or electronic unit injectors, or unit injectors at all for that matter. In the caps system, fuel injection pressure is created in the pump, and injection timing and distribution is controlled by the pump. The actual injectors are "dumb", nothing more then a nozzle and pintle.
HEUI came around in 1993 as a joint venture between cat and international.
Not my bus, just transporting for the owner, whom I am sure is watching this thread with great interest... Seems that some are pointing the finger at the CAPS pump as well as the injectors.
However, as I don't much believe in coincidences... Since the exhaust would seemingly have nothing to do with injector problems, I find it interesting that the flex pipe just 'decided' to let go / break about the time this occurred, so I'm going to float a theory here...
Is it at all possible the turbo could have quit or have started going out? Injectors are one thing, and are showing to be at least part of the cause here, but is it possible any of this is from a turbo going out? As in perhaps turbo problems exacerbating minor injector issues to affect engine operation issues that wouldn't be as bad otherwise? Obviously there are injector issues that need to be addressed, but I'm wondering now if the injectors are entirely the problem... *shrugs*
I ask because now that I think about it, I don't remember hearing the turbo through all of this diagnostic. It seems to me that the CAPS pump would be calibrated to fuel for the extra fuel needs of a boosted engine, therefore if the turbo went out, that would cause issues.
Wow ... we just spent 224 hours to travel 4000 miles and had an experience much the same as you have just described. Our CAT 3126 was purring along at 68 MPH and I felt a slight "caugh" then all was well. After another 50 miles or so, we wanted to stop for breakfast. When we got down to idle speed, it started to run rough ... so much so that we decided to keep rolling because we were NOWHERE, Indiana. At highway speed it continued to run fine. I also noticed the "water in fuel" light was intermittent. So we pulled into a rest area and it was rough and died as we parked it. There was white/grey smoke coming out before it died. I drained some fuel out of the separator and found some sediment, but no water. I used the manual prime (lots of pumps and little pressure) and was able to get it running ... rough and white/grey smoke. The smoke was also coming out of the turbo-to-exhaust pipe clamp area. I let the engine cool down enough so I could tighten the clamp again as it was so loose the weight of the clamp nut caused it to rotate from the top to the bottom of the pipe. After tightening the clamp and priming again, it started with the smoke again. Once it was rolling the smoke quit and it seemed to run great until we got down to idle. We pulled into a station and added a half tank of diesel and diesel conditioner and after the initial smoke, it was able to idle fine. We had absolutely no problems with it after that.
My take is that we picked up some bad fuel at our prior fuel stop.
Ted
Interesting that you mention the Davco unit. I drove a Pete 386 once that had such a unit. This truck had two very strange phenomena going on.
First, running at the governed speed of 66 mph, it would routinely spike a code for High Exhaust Temp, yet, no one could ever find the problem.
Second, every time that truck went through a rainstorm, the "Water In Fuel" light would come on without fail. Bleed it off and all was well.
I always suspected there was a slight breach in that Davco unit, because it was not a factory Paccar unit to my knowledge. However, the truck never failed to start, nor did it ever have fuel issues to my knowledge. Just thought I'd pass along my observations.
Wow ... we just spent 224 hours to travel 4000 miles and had an experience much the same as you have just described. Our CAT 3126 was purring along at 68 MPH and I felt a slight "caugh" then all was well. After another 50 miles or so, down to idle speed, it started to run rough ... At highway speed it continued to run fine. There was white/grey smoke coming out before it died. Once it was rolling the smoke quit and it seemed to run great until we got down to idle. My take is that we picked up some bad fuel at our prior fuel stop.
You know, this makes a lot of sense now that I think about it. When the second mechanic was tinkering with the loose / leaking injectors, the smoke did not go away even when the misfire did. That kind of points to a fuel pressure problem at the source, now that I think about it some more. Hopefully it's just a clog, hasn't been that way long, and hasn't hurt the CAPS pump... But if it's bad fuel, and it has to be pumped out and disposed of... :hide:
Assuming that it is a bad fuel or clog problem (Mandinee tells me that there have been problems with diesel fuel having to be dumped because it's not getting used quickly enough, something I wasn't aware of) -- Bus was running fine when I fueled at the TA in Barkeyville PA. The chatter noise at 1500 rpm and having to downshift manually started, I'd say around an hour before I stopped in Drums PA and noticed the rough idle. 227 miles according to Google Maps, and if Native is right, possibly starving for fuel for as much as 50-60 miles. Any ideas if that could have damaged the CAPS pump?
The flex pipe could have been in poor shape before it broke. If you ever watch a bus engine misfire, it shakes the engine pretty badly, so if it was shaking and flexing a poor flex pipe, that could have caused it to break.
Bad fuel is a possibility. Poor injection quality at idle/low speeds can be caused by bad fuel, and would show up as what you're describing. Maybe toss in a bottle or two of fuel additive in the tank, replace the filters and prefill them with fresh fuel, and then top of the fuel tank.
A competent mechanic should be able to diagnose what you have going on though.
You didn't say it, or maybe I missed it, but has the check engine light come on during any of this? Does it come on during bulb check when you initially key on?
Actually, I didn't mention it, but no. Engine temp, oil pressure and the like have been in the green the entire trip to my knowledge, though I have to say I am not a fan of Blue Bird's unigauge cluster. However, no check engine light, no stop engine light, no water in fuel light, nothing. And I'm pretty sure I remember all bulbs coming on during bulb check, though it could have burned out during the trip.
When the service brake pedal is depressed, a red light comes on the dash that I can't quite identify, because I haven't seen it before, but I'm guessing it is simply there to indicate the brake lights are working or that the foundation brakes are applied. Perhaps someone here can shed some light on that one. I have noticed no obvious operational problems with the brakes.
That aside, I have noticed nothing out of the ordinary other than a bit of excessive lash in the steering (2, maybe 3 inches on, by my estimation, an 18-inch steering wheel), so there is likely some steering gear or linkage wear to contend with, as it wanders a bit. But otherwise the bus ran and drove well, until this business popped up. I definitely think it's worth fixing, it obviously was in reasonably decent mechanical condition to run over 1200 miles (900 of it in one day) before catching the vapors. Hence my remark earlier that I think Mandinee has made a decent purchase that needs a little TLC.
I might add that a good chunk of the first leg of the trip was running at 70-72 mph. I don't usually drive that fast, as 63 mph tends to make for stress-free driving in my experience, but I was interested in verifying some info given the new owners, also to see what kind of fuel economy numbers were doable at speed with a car in tow, as this is in the new owners' plans as well. I wanted to be able to give them some real-world info about their new purchase.
So I'm leaning toward the theory that this is a simpler problem than it seems, as existing problems would likely have become evident much sooner.
I am new enough to the bus scene that I don't really have any guesses to offer. I can tell you that the red light on the dash when you press on the brake is doing exactly what you think it is. My '99 BB has the same thing so I did some digging until I found info telling me that. I am quite interested in what your MPG findings are. I will be towing a car on trailer weighing about 6000 lbs total, and would like to run at the 70 mph mark if it nets something close to 10 mpg. I'm glad to hear you think this was a good purchase for them. Anything 20+ years old will need something we don't expect, we have all experienced that. Hopefully you are right and it's just something simple.
The dash light you see when you press the brakes is the "brake lights on" indicator. It's useful if your brake sticks a bit and you park the bus with the lights still on.
Your symptoms sound a bit like an issue i had with my TC2000 a while back, that ended up being the fuel filter and water separator. I learned something that day. Very intermittent but enough that i couldn't maintain highway speed. My thread about it is here: https://www.skoolie.net/forums/f39/12v-5-9-intermittent-power-drop-and-white-smoke-25235.html
Sooooo...
I'm told Cummins On-Site found a gross balve lash adjustment issue, particularly bad on one cylinder, #3 intake. According to the info I have, They road tested and said was all good. Even though Mandinee mentioned the two injectors I told them were loose / leaking, they said nothing was wrong with them.
Less than an hour underway, the misfire returned. Got it to a rest area. Boy, am I glad I have my car with me to get to a hotel... I just hope there isn't thread damage in the head, I'm quite sure the injector I mentioned had backed off has loosened up again... Why, oh, WHY, can't people listen to the info given them and do their job RIGHT! :banghead:
This sure is turning into quite an adventure. How far are you from the final destination?
Odyssey is more like it... :rolleyes: 425-450 miles I believe. Barring any other issues, if this is an injector issue, once resolved it will continue to run properly and finish the trip. Couple other things will need attention for long-term roadworthiness, but nothing that I believe will prevent delivery.
The injector issues, quite frankly, are something I think the seller knew about and just didn't want to bother with. They aren't something most shops are going to dig deep enough to find, because they aren't obvious and don't affect operation until driven. Which hopefully doesn't mean threading issues for the one that is loose.
The one leaking, I now believe is responsible for all the grime and crud on the trans case, as the two in question are bellhousing end of engine (#5 / #6, unless Cummins does this differently). A leaking injector is usually simple enough, but the one that keeps backing off concerns me, because it may not be an easy fix.
I just hope it's truly injector issues, and not the problem outlined in this thread I found, which is likely the reason valve lash adjustment is a maintenance item. It's acting exactly like it did before, which makes me wonder. And should this turn out to be the case, I'd venture a guess that the previous owner knew... and likely why they sold it.
Here is some other good info for 8.3 ISC owners I found... which hopefully doesn't figure into the issues with this bus.
And it's honestly not the bus' fault. The valvetrain adjustment, to me, is a maintenance item that many skip believing it is unnnecessary. Let this be a lesson -- if it's a maintenance item, it's a maintenance item for a reason. And manufacturers generally recommend certain fluids for a reason.
Thank you everyone for all your input and help. Adventure, odyssey, s*** show... there are quite a few names for this voyage so far. Props and thanks to James for taking the beatings out there, and woe to us taking a beating to our wallet.
The latest news is the problem is the cam shaft. The bus is getting towed to the shop tomorrow for further investigation, and likely a hefty bill...
We are choosing to plow through with our purchase and bite the bullet and hope it gets better, not worse, from here!
Also, if anyone is interested, I let the guy we bought the bus from know what was going on, he was genuinely shocked and upset and has offered to refund us some money, so many thanks to him as well.
