JackE
I'll be adding the next one on the other side of the bus next weekend. My and plan is to run 3 power sources (shore, generator, house inverter) through an auto switch and then into the main power box. Less confusing and less wiring than having two separate circuits. I don't ever foresee a need to run power from 2 different sources at the same time. I may also add one outlet at the front of the bus right by the block heater so I have the easy option of plugging in the engine from the house electrical system.I so muh agree that outlets on the outside are needed. I plan to have one that is raw generator/shore supplied and one house supplied. Since we are still using the bus as a moving van, I have lots of time to plan it out. I may put one of each in a socket box and one on each side of the bus. Then I can choose the power source as well as the side of the bus.
