Noticed the relay going to the larger skirt mounted condenser was smoking and melting. Took the key out, and the condenser fans wouldn't turn off. Unplugged the batteries and then the fuse.
That's for the A/C in the ceiling mounted unit in the back. The OEM dash A/C still kinda works, but will blow hot air intermittently.
Does this indicate a common problem in the compressor or water in the lines?
The bus sat in Nevada over the winter, freezing and dust are both very likely.
Looking at new condensers, they are crazy expensive! Is there a good DIY way to fix this?
Or if I do have to replace it, is there a better aftermarket cooling option?
