cadillackid
Big thing if trying to run A/C off solar or batteries. is INSULATE.. . and block off space you dont need.. a mini split is an efficient system. but still on full blast may pull 1000 watts.. which is a lot of Juice unless you are one of the few here running PRIUS or Volt battery packs that pack a good punch..
getting your minisplit to run at 80% or less of its rated capacity nets you the highest efficiency..
if you are installing a system with the intentions of leaving a pet unattended for long periods of time.. ie you are at work and dog is in the bus.. then please install some time of remote monitor alarm or such that can alert you should something fail and the inside temperature goes up..
unlike a house, the inside of your bus is going to heat up very quickly should a breaker trip, A/C bust, batteries go dead, etc..
