Ok Update, I've learned a lot since August of 2024 on this thread, and I've been contemplating my AT545 to AT1000 6 speed upgrade a lot.
As cool as the Au device is, I think I'm going to go with a CAC solution. I called them to get my options and here is what they told me. I double clarified each item with them to be sure they understood what I was asking.
They said that an Allison 1000 does not even need to talk to the ECM of the 3 Box, and it will work fine as long as it has the right tune in the TCM, and that we don't have to lose cruise control.
They also stated they may or may not have to replace/modify the TPS, it would depend on what they see. But they've done over 15 buses like mine they've said and all have maintained cruise control ability, which I'm growing fond of after having done 2 recent trips, but some 3 box's they did not have to replace the TPS and some they did. Not sure what the difference here is.
Regarding the tune of the TCM. The TCM is still used by the transmission but can receive values another way than talking to the ECM, similar to the Modulator on the AT545, but using that signal to the TCM itself. In this way, you can use an AT1000 like a mechanical transmission and it will shift properly if you have the right TCM programming. They have several profiles for tuning from Allison themselves that can handle this they said. It's not custom, and is official. Allison apparently has the capability to run modern Transmissions as mechanical, but isn't commonly used but CAC has access to the tunes.
They asked me questions about what my T444E is governed at currently. I told them, I can modify the governor in the ECM, I have that capability. (they were a little surprised by that but they said okay, set it to 2800 RPM) I asked them what's better? a 2300 RPM tune or a 2600, or a 2800 RPM Tune?
They recommend if I can program the governor to 2800 RPM they have a proven great shift pattern for the 3 Box buses tuned for full throttle at 2700 RPM and that with that tune, I would be achieving 65 MPH at only 1600 RPM, and by 2700 RPM, I'd be puckering up at 80+ MPH. And they also recommend I install an upgraded 3 phase torque converter since it's a BUS and it would be better for it due to weight distribution reasons with the AT1000, which without one may be why we've know buses doing this have poor shifting capability.
I know this will be a more costly route, but they do the install, and I have peace of mind.
I'm not that mechanically ready to deal with something of this magnitude, and I'd prefer to have them do it since they seem to be pros at it, sounded confident, and has been doing it since the 80's.
Also, regarding the AT1000, I asked if I should get it overbuilt, and they said unless you plan to be up in the 38,000 lb range it's not needed. I told them I will likely end up in the 26,000-28000 lb range, and they said absolutely not needed to be overbuilt, a standard AT1000 will be fine for your application and could pull a car behind you still.
Thoughts?
