We have FINALLY gotten all the windows cleaned and reinstalled. We replaced 8 windows with 18 gauge sheet steel. We still need to sikkaflex the outside, but the inside is all done. I used rigid foam insulation shoved up under the rib above the window to and at the bottom to help keep it flat in place while we screwed them in and that worked well. We tried various approaches to pushing against the metal while my son drilled into it and what worked the best was holding the end of a 2x2 flat against the area he was drilling.
We still need metal for one window and the 2 ceiling hatches. Can I use the piece of ceiling I removed for the hatches or is it not low enough gauge? It's curved, so being able to curve the metal could be good. I could double it up if needed?
We also installed the wood furring strips below all the windows (we didn't do that where we have metal). The furring strips have thin slices of foam insulation behind them to make them flush with the chair rail below them. The spray glue I used said it was foam safe but it sort of ate it a little bit but it's all still as even as it's gonna get in a bus that is not square nor level anyway.
We examined the air tank today and discovered this: this looks like it might be a way to attach a tool or something to the tank? We also figured out the autochains are moved up and down with the air. I do NOT see how the door connects to the tank. I guess the air goes up to the front of the bus and then branches off to the door and whatever else up there uses it? The seat doesn't have air ride so it isn't that.
We started Mobi again today. The battery has been unhooked and despite the fact that it was pushing 80 Mobi did not want to start without a little time on the block heater. We really have to replace the glow plugs if we ever want to be able to drive him anywhere! Then again, we'd also have to reinstall the seat and figure out why the clearance lights and windshield wipers no longer work.
My son fixed a wire I accidentally got with the angle grinder while convincing one of the windows back in the opening after pulling them all and did some other electrical stuff.
Our hole saw does NOT want to cut the bus metal. I don't own a jig saw. How do people do that? The sawzsall would make an unholy mess.
I am feeling much better having gotten the windows back in and openings covered so that if it rains we no longer have to run out and tarp it. We are also one step closer to being able to spray foam which I somehow thought we would be able to do a month ago. Um, no.
So can I attach a tool to the valve thing on the bottom of my air tank?
