Advice on a gasser, please
lack of info on craigslist post makes me feel that the guy is looking to make a quick buck. I hate posts that don't have enough detail or pics. i'd pass
As gas engines go, the 454 is common in RV's and motorhomes. Unfortunately this 454 is backed by the least desirable trans. The rust on the fender of a Texas bus concerns me enough to avoid an offer.
New tires and new motor are something to consider. Rusty fender can be fixed, I'd have to personally inspect the rest first,
That's not rust. The hood is all fiberglass. What you are seeing is simply the paint worn through to the base fiberglass, which isn't all that uncommon.
The 454 isn't a bad engine for occasional local use. I wouldn't want one for much long distance cruising especially if you ever plan to ascend any hills. The fuel economy alone will kill you in gas.
Thanks for the information.
Looks about common for that age, usually people will ask around 2,500 then bargain down to 2,200 or 2,000
One thing to look for in Texas is flood damage. last year hundreds of thousands of vehicles got and are being resold with it.
Thanks for reminding about Harvey! Definitely will keep an eye out for that.
Thank you for the information. I thought it was fiberglass too.
Gas is a non-starter for me. You have to be a pretty slick salesperson to convince someone to get half the MPG and 100k mile overhaul intervals, but obviously it happens!
the windshield pic seems to indicate a new 454 and good tires... 2700 is high.. the mileage on that will likely be in the 4-6 range.. I had a 454 tall Deck years ago.. good solid motor.. not real powerful and not good on gas but parts are still very available for them.. alot depends on what you plan to do with it.. I'd talk the dude down to 2k or below.. and yeah look for any signs of water damage.. esp to the interior.. is the rubber buckled or such indicating water made it up to the floor.. is the trans fluid stick milky indicating water over the trans vent at some point..
if its a weekend warrior that you don t plan to run all over the country putting 1000s of miles on per year a gasser is not a bad way to go.. but diesel is much more efficient and built for longevity if you are going to run it alot..
