somewhereinusa
BusFiend
Sent you a PM
Sent you a PM
Heads up received. The two young guys (30ish) I spoke with in person seemed on the up and up too. Now I'm not sure what I'm going to do. I'll take a look for another coach builder. But most of them are plenty far from the NYC-Philly corridor. Anyone have any recommendations? My deadline is Jan. 1st.
Don't have a bus yet. Trying to put a design together first and purchase a donor to best fit the design.
Interesting thought on modifying the kneeling valve. First thought is school buses with front air seem to be rare. Retrofitting a complete front air suspension may be beyond my budget. What does it take to add a kneeling valve to the rear? Collapsing the air bags for kneeling has to lower the spring rate of the system. How would spring rate be calculated?
Pushing a tight deadline, there's a time/$ saving if you reuse some seat frames. Then just have units on them. Eg bed unit, bunks unit etc.
Then you can have fitout guys building bolt in units while the interior is being gutted/wired etc.
If you're planning on bouncing down very rough roads it'll help with dealing with the extra flex the bus gets subjected to.
I've been communicating with a bus engineer who is concerned about the additional flex cracking/snapping the hat channel... I have no clue what I'm going to do.
I really want to wire, plumb and finish the interior myself. I just want a coach company to give me an empty, primered, insulated shell. Apparently, I can get this directly from Blue Bird, brand new, for $45k...
I may be better off finding a travel trailer that needs some help, grabbing a 3/4 ton pickup and be done with it.
With a computer, they're a progressive rate not linear rate spring. The equations to do it are in most adaptive suspension research papers. The maths gets a bit complex without a computer.
The kneeling valve just takes some pipework and a valve and a brake switch and a lock it out unless stopped mechanism.
For going up instead of down, the leveling valve needs to be fooled. Most air bag systems sit at about 2/3travel, all you're doing is moving that up to 3/3 travel. Using stock bits nothing should get damaged as it's within a designed failure parameter, broken leveling valve.
Folks put too much faith in school bus off road capability.
They actually get stuck pretty easily. Ask hank.
If you will be moving a lot, go with the bus. Otherwise, a trailer / 5er will be the better setup. The key to off-road is ground clearance and airing down the tires, even the trailer. Get a compressor and a spare for getting back on the highway.
I have a 3/4 ton 4x4 and 29' 5er, does well off road. Flipped the axels on the 5er for decent clearance.
Would you like me to post some pictures of what I did? The base of the unit to the seat frames mount and it's controlled movement is how I engineered it so it doesn't pull the Channel out of the wall.
check out custom coach in columbusd ohio area... they have done some fantastic conversions in the past... mainly ive seen trip busses from them but they may very well do a skoolie..
columbus ohio is not that far from the east coast corridor... its a quick airplane flight and easy drive if comin g to get progress reports on a cxonversion... plus I live here in columbus..
they did get absorbed by farber specialty.. but i believe they still do bus conversions..
Farber Specialty Vehicles - Custom Coach
