welcomehome
2000 international 3800 t444e bluebird with at545 transmission.
i recently got my first bus. lots of starting issues over this last 4 months of having her. upon pulling the starter i noticed worn teeth on the bendix gear and upon closer inspection i saw multiple spots of broken teeth on the flexplate. so i have to replace the flexplate.
multiple people that i have talked to have told me it is a hard job , and that they have done it, but it is a pita. however all of these people have did it on a manual transmission, which im learning, makes it a flywheel for them.
shopped around and found shops expecting from 1500 to 2000 to change out the starter and flexplate including parts and labor.
blessed with a concrete driveway and understanding inlaws whose house we are visiting, i see no other financial option than to study up on it and do the work myself.
i have been down there quite a bit looking at all the things i would have to disconnect to take down the tranny in order to pull it out from under the bus to get the flexplate off. i wonder if there are any idiosyncrasies about this international 7.3 liter engine that i need to know or special tools i will need to do the job? what other seals or other things would i also need to do?
does anyone have any advise on this job? thank you so much.
