Booyah45828
You should build full pressure in a handful of minutes. If you've gone 20-30 without pressure showing you have a pretty large leak somewhere. It should be easy to find, crawl around the tanks/hoses and drier and see if you can find air movement. If you find none, remove the hose from the compressor to the drier at the drier and see if you have air flow out of that.
To release the brakes, it normally requires a minimum of 60 psi. But that's irrelevant, because if you can't get more then that, you have leaks that need to be addressed. There's a leakdown spec for air systems, and it's 5psi leaked per 2 minutes. If you're above that, the bus shouldn't be driven.
If you can't build any pressure, I'd bet good money you're well above the leakdown spec.
