So I’m trying to pop the rivets on my skoolie with an air hammer to raise the roof. Problem is the air compressor keeps cutting off, I think it’s tripping the generator. It’s a 3000 watt generator, the air compressor is a 10 gallon, 120 volt, 13 amp, runs 4.3 scfm @ 90 PSI. The air hammer needs 4cfm @90 PSI. The first day I went an hour or so before the air compressor cut off. The compressor is brand new out the box generator is a rental. The next day it would only run for maybe 15 minutes before cutting off.
There is no power at the lot my bus is on so I really need an air compressor/generator set up to work.. Generator has oil and gas and is not turning off when the air compressor does. Compressor doesn’t use oil so it’s not that.
I think I’m going to return the compressor and try renting a bigger compressor and generator but idk if that will solve my problem… any ideas?
