cadillackid
sounds like the heater in your air dryer is the issue.. now that its warm is it all working normally? you should be losing pressure when you apply the brakes thats normal.. when the pressure drops below the governor set point the compressor kicks back in and recharges the system.. the air dryer purges (Shhhh sound) when the governor turns OFF... there is a replaceable heating element in the bottom of the air dryer.. make sure you have power to the heater wires whenever the bus is turned on.. they will be the only wires going to the air dryer.. some have a singke wire and then assume the dryer is bolted to ground, others have a 2 pin connector..
its pretty common for that heating element to burn out over time.. or the fuse to pop and cause the wire to have no power..
the element is powered anytime the key is 'on', it has a thermostat to turn it off in warm weather..
