TheHubbardBus
We're keeping our bi-fold air door because it's cool. What's not cool is it isn't working properly at the moment. It has worked perfectly for periods of time, interspersed with periods of erratic behavior. My main problem is I don't know how this system works.
Does anyone have any resources / manuals / online instructionals that would detail the parts of such a system and how they work together?
I've ruled out the air-door switch, and it's highly-unlikely to be either the linkage or the piston. That leaves the regulator, a component just downstream from the regulator that does I-dont-know-what, and the mechanism sitting atop the piston with the door open/close speed controls. The last item is what I'm guessing to be the most likely source of trouble, but I can't say for sure.
Not necessarily looking for advice other than how/where to learn, but if you've got some...
One potential clue is that even when you switch the door to 'manual', the door doesn't release. For this reason I've had to disable the system entirely to prevent being locked out.
Thanks in advance.
2004 IC CE200/300
Thanks in advance.
2004 IC CE200/300
