It’s coming from the ring around that main part I posted .That is your air dryer. You could have a leaking purge valve or check your air line connections to and from the dryer.
Leaking right where it looks like the bottom piece isn’t flush with the top anymoreThat is your air dryer. You could have a leaking purge valve or check your air line connections to and from the dryer.
