nikitis
I already know for starting this thread I'm going to get a lot of flack for mentioning such a thread so I'll stop you ahead of time and mention the dangers in this first post.
The point of it is so that we can learn how our buses work. I believe in freedom and in your ability to make responsible decisions.
Not all beepers/buzzers are alike on all buses, so if you've done this mod, please feel free to post in this thread pictures of what you've done.
WARNING!!!: Do not do this mod if you are the kind of person who may "Forget" items in a checklist occasionally etc. Your life, but more importantly other lives may be forfeit if you ignore this warning. There can be no room for error if you do this mod. Consider yourselves warned and I nor anyone here will be held responsible for your irresponsible decisions and you take full responsibility for continuing.
What is the mod?
The mod is to add a rocker switch that can disable Air Pressure Beeper/Buzzer Warning sounds while you do diagnoses, modification, repairs, etc, but NOT while driving. The switch will also include a RED LIGHT INDICATOR to be installed and added to also give people a visual indicator as a backup in case you do forget to turn it back on before you drive, but again if you do forget even once, you shouldn't do this mod. Regarding the beeper/buzzer, YOU NEED THIS WHILE DRIVING. This is required because you need to audibly hear noise should your brakes begin to fail while driving and to buy you a few more brake pumps before you lose air completely. This can cause wrecks, deaths for you and others. The point of this mod is not to disable while driving, but while working on the bus while parked.
Reasons for doing this:
This thread is to document my experiences and others experiences for my bus model and others buses as well to be able to disable the Air pressure warning beep/buzzer when you want to work on "Other" electrical items and require a "Key ON" event.
When you need to concentrate on ECM values in ServiceMaxx or NavCal or fixing light wiring and testing etc, you don't need that buzzing or beeping directly in your ear. This is more than a mere annoyance for some. We literally cannot concentrate, and I'm sure i'm going deaf quickly buy entertaining it. We don't need air pressure warnings when doing such activities.
Additionally, most of us are adults and should be capable of following proceedures before driving a bus. If you aren't you shouldn't be driving a bus, but if you can't always do your checklists 100%, do not do this modification. I believe everyone should have knowledge, and knowing how your bus works is one of the fundamental requirements of our movement, and it should include how this item works. My hope is that you'll know better how to service it, replace it should it be dying, or possibly change the tone so it's audible but not so loud, they do make softer tone versions of these you can replace yours with that still serve it's purpose.
Tomorrow I will try to locate my beeper in my bus. I know it's near the dash, likely behind the rocker panel, but I've noticed that when my head is below my dash's hood, it's louder than when I'm above it. I'm usually below when working on ECM issues as my 6-port J1708 jack is under the dash to the far left wall on my bus, not in the middle where it's as easy to access like on newer buses.
What is the mod?
