Air Pressure Beep Disable Modification.
Why dont you just start the engine and fill up the air tanks?
Problem solved !
And if you lose air quickly, you got bigger problems!
Put a fitting in the air tank bung to hook the shop air compressor to, that's what the wrecker driver's do if they have to tow an air brake equipped vehicle. It's lots quicker than caging brake cans.
This has been suggested however, I personally don't have a shop air compressor.
Others do not as well.
Additionally Beyond the front and rear slack adjusters and service chambers I've not messed with my air system beyond that, so I'm not well versed in even to know how to set such a system up yet. For me the electrical is far easier to do, and I'm doing it in such a way I'll be reminded to re-enable the buzzer before driving with the light.
Why not just use ear plugs/muffs? Or put something over top of the buzzer when working on it?
I could potentially wear ear plugs while doing some things but repairs may require I listen to the sounds that are being made.
The beeper not buzzer in my case is difficult to reach. There's literally no room to cover it where international put it. I could barely finagle a screw driver through the wire harness to relocate the beeper, yes through the middle of the harness because the wiring is so tight I couldn't move the harness to the side to use the driver. That's how tight it is to try to put something on top of it would be too difficult.
That being said I still had to modify the location of it to where it is now reachable to where I probably could just cover it with a cap. But Because of the loudness / intensity of the sound it would probably penetrate whatever I put on it. Also the back side is against a wall making it difficult to cap. And I don't have a suitable cap. Where would one search for one? Nothing is made to cap it sufficiently that I can purchase and what happens when I forget I capped it this making it less safe than my method. You at least get a reminder with my method if you forget and is a better solution and is more clean and safe than just capping it
on the construction equipment at work some of the back up alarms are deafening.
i put duct tape over them.
you can still hear them but it drowns out alot of the excess and they can still be heard.
Skoolie Certification Process
Does this thread make the Skoolie Certification Process thread null and void?
Quote from that thread: " I've been reading about all of the problems that go along with Skoolie building. Mainly legal problems and obtaining insurance and additionally safety issues people create for themselves." :confused:
It shouldn't if you follow the safety procedures which will be set. Which will include:
Proper labeling of the switch, and light.
Using a light as the safety backup to remind the driver to turn the beeper back on while driving, (Rather than just a switch to disable the beeper which can cause the driver to forget he disabled it and putting him and others in danger). The light will remind the driver should he forget to disable the Diagnose/repair disable switch.
The modification is also a valid legal mod to use if you are a hearing impaired driver.
Uses proper gauge wiring and proper wire connecting bits (No twisting wires together and only using electrical tape). Can't be any chance of disconnecting so a quality wiring job must be done.
I'll have a video coming out in a few mins of it working. I have it installed now. I still have to print out the labels, I'll demonstrate that in video 3. Video 2 coming in a few mins.
Video is below. It is age restricted so young folk cannot view it.
It's demonstrating it working and installed, (Minus the labels, coming in video 3)
damn straight if your insurance company knew you made this mod you would be cancelled in a heartbeat......
Maybe they would, maybe they wouldn't. If I had a chance to explain who knows. I have a good argument. You can disable the alarm in a modern international truck during diagnosing. I've kept it safe by adding a notification to let me know it's not enabled and to turn on the beeper should I forget. You guys are being a bit ridiculous honestly. There will NEVER be a scenario where I will be driving with the beeper off and it will work. So what has changed?
Absolutely nothing other than I can now work on my vehicle in peace. Others will be able to as well. And I've joined the ranks with the modern International trucks. Once the diagrams are released. I'll enable people by educating them. I also teach them to be safe about it. What the law is in case they didnt know and why it's important to do it right should they go through with this. How is that not making the world a safer and free'er place?
Keeping people safe through obscurity is willful ignorance and it keeps people in the dark and sometimes has the opposite effect of keeping them safe like someone trying to do what I'm doing but in a less safe manner like just simply unplugging the beeper with no reminder to plug it back in. By doing this I've demonstrated I'm taking measures to be safe about it. I don't believe in that mentality of living in ignorance. I'm not putting anyone in harms way. We can't be truly free if knowledge is kept in the dark and I disagree with the practice in the automotive world. I want to enable people but in a safe manner. Secrets are the reason we cannot fix modern buses anymore without the keepers of the keys a.k.a. Stealerships.
I'm increasing ones understanding of how a system works so they can also self repair in the event their beeper just breaks, they can diagnose and fix themselves.
If I had come here and worded this thread like "Hey, my air pressure beeper died, how do I fix it, you guys would be all over to help with that, but because I want to save my engine, and components and air compressor which is already ancient by automotive standards and not wear them out faster this is some crazy to you guys. I don't get it honestly. I'm not worried about myself so you shouldn't be
Insurance companies already cancel for roof raises and stoves and roof decks, that doesn't stop people from doing them. Nor should they stop doing them but they should do them in a way that is correct and would make them safer as I am doing with this project.
If you don't feel morally right assisting, that is fine, I did it on my own and I will help others who wish to do the same thing.
I really don't understand the grand standing. The way I've done it is safe and it will always work. Guaranteed.
In aviation we have a warning sound mute button. It has an interlock that keeps it muted till another warning event or aircraft shutdown. It is useful for when starting the aircraft to silence all the horns and buzzers while the warning lights are still lit
I would say that a system like that would be much safer than a rocker
I'm aviation we have a warning time mute button. It has an interlock that keeps it muted till the earning event or aircraft shutdown. It is useful for when starting the aircraft to silence all the horns and buzzers while the warning lights are still lit
Sure. Do you want to design one?
There comes a point of reasonable expectation of what can be done vs costs of doing it. The reminder with the labeled light will always tell you to turn on the beeper should you forget, you can't miss it. No more than you can miss a Transmission fault light. You're gonna see it and flip the switch back on for the beeper.
how about we call DOT and see what they think of your safety device... if its truly as safe as you claim it to be then a DOT inspection should be no issue... they should affirm yout thoights that you are just as safe as an automatic buzzer on low PSI....
if it passes a DOT inspection then it should be no issue to the insurance company either....
That's an idea, I've just finished calling them. I explained my situation to them and they said it was fine and that I've met the safety requirements.
"An Audible warning is not required if there is a visual one on the dash and can be seen from the drivers perspective easily enough. It requires 571.101 Standard No. 101 to be in compliance to have the light indicator indicate what it's for. "
So I'll have to add a label to the light to instruct the driver to "Low Air Pressure Warning" at a minimum by the light.
The interesting part is Section 5 of that standard says it's not required on vehicles with GVWR's of 4536 kg (10,000 lbs) or greater if vehicles are older than September 1, 2013. So the FMCSA guy wasn't even aware of that part of the label, however while not required I'll still label it because I don't think that's safe to not add even on older vehicles.
From the regulations:
S5. Requirements. Each passenger car, multipurpose passenger vehicle, truck and bus that is fitted with a control, a telltale or an indicator listed in Table 1 or Table 2 must meet the requirements of this standard for the location, identification, color, and illumination of that control, telltale or indicator. However, the requirements for telltales and indicators do not apply to vehicles with GVWRs of 4,536 kg or greater if these specified vehicles are manufactured before September 1, 2013.
They only require a "Warning signal" It doesn't specify that it has to be Audible, it can be visual.
(c) Air brakes. A commercial motor vehicle (regardless of the date of manufacture) equipped with service brakes activated by compressed air (air brakes) or a commercial motor vehicle towing a vehicle with service brakes activated by compressed air (air brakes) must be equipped with a pressure gauge and a warning signal. Trucks, truck tractors, and buses manufactured on or after March 1, 1975, must, at a minimum, have a pressure gauge and a warning signal which meets the requirements of FMVSS No. 121 (S5.1.4 for the pressure gauge and S5.1.5 for the warning signal) applicable to the vehicle on the date of manufacture of the vehicle. Power units to which FMVSS No. 571.121 was not applicable on the date of manufacture of the vehicle must be equipped with—
(1) A pressure gauge, visible to a person seated in the normal driving position, which indicates the air pressure (in kilopascals (kPa) or pounds per square inch (psi)) available for braking; and
(2) A warning signal that is audible or visible to a person in the normal driving position and provides a continuous warning to the driver whenever the air pressure in the service reservoir system is at 379 kPa (55 psi) and below, or one-half of the compressor governor cutout pressure, whichever is less.
So to sum it up. I've not violated any regulations by doing what I'm doing, It is considered safe, I will not lose insurance over it.
If I wanted to I can install a Wigwag as my warning signal and not have an audible beeper at all.
The beeper is not even required if there's a visual indicator. I could leave it and just have the light according to the regulation and since it's so old technically doesn't even have to be labeled because the vehicle is so old, (however I don't agree with that, I will label it, and I will require when we do the safety certification to have them labeled even though DOT doesn't require it I think we should require it in our skoolie cert.)
So to be clear, a Wig wag only device could be all I require for a visual indicator to meet DOT requirements. Or I could have just a light properly labeled. Or, I could just have the beeper.
All of which are considered legal and safe. End of story. Let's move on now.
Just because you can, doesn't mean that you should.
I know it can be difficult to pull yourself out of a mental track where you go down the spiral of false justifications. When you are in that state you can not see out.
Please let the skoolie.net community assist you in getting out of that spiral. We have all commented on this out of concern.
hey, in defense of nikitis,
y'all are arguing over stuff that dosent matter.
he should be registered as an rv. and rv's are not commercial. rv's dont need to be safe.
the quote from the whomever is laughable. the regulation doesnt apply to skoolies being made into rv's. it applies to commercial vehicles only.
unless your state requires a safety inspection, he can disconnect it completely.
darwin is our vehicle safety enforcer
the use of shop air is the correct answer. your complaint of your compressor not being adequate is lame. you need to fix those air leaks.
Well technically mine is still registered as a Bus on Title. Being as South Carolina won't allow conversions to RV on title, and if they find out it's a bus but listed as RV during their investigation of the VIN history, they look up the origination they will reconvert it back to Bus on title. So it does apply to me, however I've just stated the law, and had a DOT guy also confirm, and I'm within the bounds of the law so any further nay sayers can get over it.
Unless you’re talking about death or taxes, I would avoid using the word “always”…
Of course, we shouldn't deal in absolutes, but it works well and enough that it's indistinguishable from a natural fault so I'm not worried about it. I was just trying to satiate the nay sayers over it. Poor wording on my part.
I have a wire with croc clips to put on the pressure switch in the engine bay just for this, but I also pretrip and listen for buzzer... old habits never die! That buzzer is a lifeline!!!
