Hi Everybody. I'm a newbie and am mechanically and electrically illiterate, so please pardon my ignorance. My wife and I purchased a 2008 International RE300 recently and been demoing the inside. This bus has air brakes and the door is also equipped to be opened using air pressure.
Anyways, I had to disconnect the wires (no air line) going to the door in order to remove some of the interior panels. After doing so, I was able to park the bus. A few days later I went to move the bus and it will start, but the air pressure is not building up. I can tell the compressor is working but I cannot move the bus as the parking brake won't release since the gauge is showing low air pressure.
I believe one of the wires I disconnected may have had something to do with this. The only other things I disconnected were the security cameras internally and the radio, so I'm lead to believe it must have been something on the door. Someone told me it may have been a ground wire for the air gauge.
Anybody run into something similar or know what I should do to fix this issue?
