dtsnyder
Hey all,
Long post, and I apologize. Fingers crossed CadillacKid chimes in.
First time poster here after lurking a bit. My family and I recently purchased a 2003 International 3800 72 passenger bus with a DT466E and Allison 2000 transmission. 128k miles. Drove to Alabama with my daughter and brought it back to South Carolina with no issues. The bus ran great.
The bus has been in between storage and the house to do minor things (remove seats, decals, etc.). One day the check trans light came on and the bus wouldn’t go past 15 MPH (approximately 2600 RPMs). Pulled over, turned the bus off and on, light went off and it drove fine.
This continued periodically. Had the bus at the house over the last weekend and when I went to take it back to storage. This time the check trans light would not turn off. I’ve dug through the Allison manuals looking for solutions and couldn’t find an easy fix. I ended up taking it to a certified Allison deal for diagnostic. This is what they found, verbatim, from the quote.
“ Tech notes: PULLED UNIT IN BAY CONNECTED DOC FOUND ONE CODE P0748 PCS A ELECTRICAL . OHMNED PCS-A AT THE TCM TO TRANS. CHECKED FOR CURRENT TEMP FOUND PCS-A IS OHMNING TO GROUND/CASE. MOVED HARNESS ALITTLE AND IT NO LONGER OHMN'S TO CASE/GROUND. PLUGGED BACK IN TO TCM AND CLEARED CODE. CODE CAME BACK AS SOON AS KOKO. PLUGGED UP OUR TEST TCM AND RETEST NO CODES SET CLUTCH TEST OK. RECONNECTED OEM TCM AND CODE RETURNED AS BEFORE. LOOKS LIKE THE SHORT TO GROUND ON PCS-A CIRCUIT TOOK THE DRIVER OUT IN THE TCM. WILL NEED TO REWIRE PCS-A FROM TCM TO TRANS AND REMOVE AND REPLACE TCM DUE TO DRIVER FAILURE FROM THE SHORT. ALL PARTS SHOW IN STOCK AT THIS TIME.”
Their suggestion is to replace the TCM ($1200, plus 2.5 hours labor) and to rewire and retest the PCS-A circuit from the TCM to the transmission (6 hours labor). All in all, about $3000. This is close to what I paid for the bus and honestly not in the budget.
I’ve seen used TCMs for $200-400 on eBay. Can I buy a new PCS-A and TCM and just plug and play? Fix the current ones? I’m okay with spending a little bit of time and money, but can’t stomach $3000 right now.
Any help is greatly appreciated. Thank you all!
