I have a 2007 international with a allison 3000 transmission, the other morning I went out to start it and the shift indicator was flashing from nutural to the cat eyes, when it was doing that the transmission was actually attempting to go into gear and turn the drive shaft. Was able to drive to the shop, checked everything underneath it all looked good, started the bus again to back it out, started and then the shift pad went black. Pulled the tcm off and took it to a dealer to have it tested, they couldn't pull anything off of it and I couldn't hook up to it with my computer either. They sold me a new one put it on and I Still don't have a shift indicator and the bus wont start, if I jump the starter solinoid it starts so I know everything on that end is good. Did my shifter short out which fried my tcm or am I missing something
If the TCM is not communicating to the ECM, bus WILL NOT start. In part, it is because the NSBU is wired thru the TCM and if the ECM does not se the bus in neutral, no start.
It starts when you jump the solenoid simply because you bypassed the NSBU function.
you said you checked all the connections.... a visible check IS NO ENOUGH!
You MUST DO a physical, not visible, check!
First place to start, the TCM fuse. If your fuse is in the BAT box, pull the fuse and look at the legs. Is one of the legs darker than the other?
Look at the fuse holder/terminal iside the inline fuse holder, same question...is one darker then the other?
If so, cut out the fuse holder and replace!
Physically check your TCM ground. This means locating the ground lug, opening it up, clean...shiny clean and reattach. this is the only valid way to check it, simply looking at it is not enough!
Once you do this, I can help you more, get in much deeper but, you got to get dirty first!
check your power and ground is ALWAYs step #1!
In the mean time, do yourself a solid and get edumecated... lot's of info here!
Hello all, I am going thru a dead shift selector panel issue. According to the dealer mechanic who has serviced this bus many times when it belonged to the school board he indicated the pink wire #124 tends to break open near the transmission. Bus in question is a 99 Amtran RE. I also...
www.skoolie.net
So after trying to help a member out I realized that I have so much info that is not organized I decided to fix the issue. I will be posting up commented docs that will help you understand how this is built and how it works. Push pad themselves DO go bad but I have no idea of the frequency...
www.skoolie.net
