Backwoods Wanderer
This is how the process to unlock 6th gear in the Allison MD3060 transmission unfolded for us:
1. Call the technical service department at your OEM and tell them you'd like to unlock 6th gear.
2. The OEM will make a determination based on review of the mechanical specs from the build of your bus. You will also need to send a picture and make/model description of your tires so they can verify the static load rating. If you do this in advance, it could save some time. Their engineering department will then make a decision as to whether the bus can handle the added stresses and speed. This can be a lengthy process and I might add doesn't contribute to their profits in any way so be patient!
3. If approval is granted, the bus then needs to be brought to a certified Allison service center to perform the work. Liability waivers will need to be signed.
4. The service center will contact Allison and request a 6th gear unlock code. If Allison is satisfied with the paperwork, they will generate an unlock code specific to that transmission and you're good to go.
This isn't an expensive thing to do but it is difficult. I wish good luck to anyone looking to try this.
If all else fails, you can always replace the rear axle with one that has a lower gear ratio. If you're handy and resourceful this can be a good option.
