Jolly Roger bus 223
04 chevy express cutaway.
owner wanted the second unit gone.
thats done the lines have all been pulled and shortened.
then the owner through her sons advice said to move the condensor from underskirt to behind the grill like normal.
thats done with custom mounts but i had to cut the factory fittings off to make it fit.
i do copper/refrigeration stuff for a living so brazing and re routing stuff is not that big of a deal and i saved all the fitting i cut out.
MY BIG QUESTION?
now dash A/C only and the compressor already has to be changed because it was already locked up and disabled.
1-would i not be safer in buying a condensor and lines that or more commonly available from a parts store then building a bastard system to send the owner down the road with.
2- is a bigger condensor better or worse for a smaller system?
i know it turns the gas back into liquid to send back to evaporater but is bigger actually better ( and wiith that in my head now i already have to be on the phone with a TRANE engineer in the morning).
the idea for just going to a standard configuration is i have a bad or soon to be bad condensor connection that is hydraulic crimp and the bad spot is right at the crimp and i live in a heavy farming , trucking and heavy equipment community and none of the hydraulic shops have the stuff to match the hose size.
biggest question is if the bigger condensor is beneficial for the extra effort to make it work for just dash A/C now or should i just replace it with the standard stuff a garage could have in a day or 2?
i think thats what they would do is rip out all of my stuff and put in the standard stuff.
and for this one when i say the owner? thats my traveling LABTECH wife and her son is my oldest as a ford mechanic.
i had her convinced to keep it all?
until he said yeah it can be done? as he says i will see you next weekend mom?
???????? owner wants???????
MY BIG QUESTION?
