I’ve got a BlueSea fuse block connected to an AC-DC converter that I’m using to mimick a final battery connection. I want to connect four circuits to it and the three that power some lights work just fine. The total draw for those are 9.7 watts. When I add the fourth circuit which is to a 12v tv (draws 17 watts) it doesn’t even turn on. I’m guessing it’s because the wattage combination is too much for the converter. If I’m sending 24v to the block…why is this happening and what’s the best way to resolve it? My plan was to push 24v from the batteries to a 24-12 step down then into the block…what am I missing?
Thanks!!
Thanks!!
