SO… Ive been doing a lot of digging on here. Ive used the search function, And I have a build thread. So I’ll keep this specific.
Looking into Hydronic. My components list is as follows.
China Boiler (or name brand one maybe?)
Flat plate exchanger (for separating the fresh water heat loop from the engine coolant heat loop)
A couple pumps (24v)
Some Pex obviously
An eBay manifold.
Expansion tank.
Here is a rough drawing of what my thoughts are. Am I missing anything?
The in floor heat portion of this is going to be very small. I intend to run a mini split, as well as one, maybe two diesel air heaters. Running fans to heat exchangers on this small of a system takes more space then its worth I think, unless I can get some real small “Heater core” style exchangers. Although, as im typing this it could work well if they’re small enough.
Let me know your thoughts, and insights with what you’ve done. Thanks!
Some Pex obviously
An eBay manifold.
Expansion tank.
