Looks like a great start.
-Tees are an issue with pressure drop if you have more than one device active at a time.
-There are 'combo units' for city water and gravity fill. They are crappy quality and degrade quickly in the sun, but handy.
-Consider an additional gravity inlet on the inside, one you can fill from pressurized city water.
-If you put shutoffs in the right locations you can use your onboard pump to recirculate the water in the tanks for flushing or treating.
-Sediment filters yes, and one is usually incorporated or comes with the 12v pump. Make it accessible for periodic maintenance.
-Put your 12v pump on an isolated surface, not the plywood wall where it will act as a speaker. Mine is on a separate panel which is in turn bungee-mounted to the cabinet.
-My water purification is only on a single (separate) faucet in the kitchen. No need to purify any other water, realistically.
-Consider Pex in place of Sharkbite.
-What type of water heater? If instant, they don't work well with mixer valves because they require pressure and flow. With instant heaters you need to regulate the shower hot water from the heater itself. Search this forum to see more details on instant water heater challenges. Pro tip: mock up the whole hot water system first and run it through paces to learn how yours operates under various pressure and flow conditions (or doesn't).
-Slope all drain lines more than the standard quarter inch to the foot, especially lines that run transverse (side to side).
