MambaJack
At the point of needing to put heat in a bus for the winter. I like the idea of the a wood stove since it doesn't fill the cabin with moisture, but am having a hard time finding something on the cheap.
The cubic mini with heat shield has low clearance tolerances which I will need. the space i have to put it is about 2' wide. Anybody use some different wood stove in their conversion that handles the tight tolerances well?
also interested in experience with the mini and if those who have installed found it worth the cost?
Thanks,
dave
Thanks,
dave
