fo4imtippin
So, i plan to put around 3500watts (Commercial panels) of solar on my bus roof. I am also working on a DIY grid tie system for my house. It would be an awful waste if my surplus solar of the bus couldn't power my house.
A. The bus systems will all be 120v, so that i can run on any shore power that i can get. I have diesel heaters, one mini split, and propane water heater planned. 6KW should power everything i need.
B. I do want to be able to run welder, plasma cutter and other 240v tools at times, so a split phase inverter (somewhat rare for US) should work.
C. I also plan to run a 48v lifepo battery bank using Server rack batteries, or if i have the energy, using cells and a BMS
D. I have a 48v 180a alternator which will be regulated to the BMS with Balmar MC-620H. This will be used to top up battery on low solar days while the bus is running.
E. Hoping i don't have to use it, but i have a gasoline 7kw inverter generator if i don't expect a lot if sun.
Whats strange to me, is i don't see a lot of people using All-In-Ones for their skoolies. Does anyone know why? They seem cheap for what they all do.
I see three main options to fulfill my needs. There are more, like paralleling MPP120v models, but cost would be high for more watts than i need.
- MPP LVX6048 6KW (Transformer) Split Phase Hybrid All In One
- Cost=$1577
- 450v PV Input (One String)
- Pro: Will allow backfeed of surplus solar to grid( my house).
- Con: Will not allow 120v plug to charge batteries
- Growatt SPF-6000T DVM-MPT 6KW (Transformer)
- Cost=$1249
- 250v PV Input (Two Strings) (Less efficient?)
- Con: Wont allow backfeed of solar to grid. Will need additional grid tie inverter.
- Pro: Will allow 120v charging
- Con: Twice as thick as MPP version
- Growatt SPF-5000ES-US 5KW with Growatt ATS-5000T-US
- Cost=$899+$349=1250
- 430v PV Input
- Con: Wont allow 120v charging
- Pro: Light and small but messy
