I now have two EU3000IS generators mounted in the engine compartment, one on each side.
The platform is a giant griddle made of 16ga steel that just happens to fit exactly. I painted it to keep it from rusting and put a layer of rubber underneath to reduce vibrations.
I took the feet off the generators and used a bolt and washer to attach them to the platform. I also removed the front and rear carry handles so the generators would fit in the space.
Each generator has a 1.5 amp battery charger with a quick disconnect to keep the battery topped off if it sits for too long.
Each generator also has the Arctic breather heater to enable use at -40 Fahrenheit. However, if I run the generator at low idle for too long, it can foul the spark plug faster than normal.
One of my generators is also equipped with a remote start. The other requires me to manually start it.
I purchased a trifuel kit to let me run one of the generators off propane. Unfortunately, the kit was defective and I had to remove it
I also purchased a 50amp WEN-brand parallel kit. It came miswired with the neutral wire attached to L2 and nothing to the neutral terminal. I fixed that, but I still need to modify it further to make the leads long enough to reach both generators.
The generators go through a 50amp automatic transfer switch along with my 50amp shore power connection. The primary transfer switch output goes to my primary circuit breaker panel that powers all my high-amp appliances (air conditioners, microwave, engine block heater, washing machine, battery chargers).
The primary transfer switch output also connects to a secondary transfer switch along with my power inverter. The secondary transfer switch connects to my secondary circuit breaker panel that powers all my low-amp appliances (lights, electrical outlets, refrigerator).
