WanderingForest
- Joined
- Apr 19, 2022
- Posts
- 21
Hey all. I just got a bus recently and have begun the long road of converting it. I have all the seats out and most of the flooring to begin rust treatment soon.
Firstly, I have some nails in the floor that were used to hold the plywood in place. They are rusted now, and can neither be hammered in, or pulled out with a hammer. I am considering grinding them off, but am worried about accidentally nicking the metal flooring. Any other ideas?
As well, I have two panels making up the side walls. The upper board is held in using pop rivets and I know I need to remove that board. The one below it has solid head rivets I would need to grind off. Just confirming I am supposed to remove both wall panels. Picture of the lower panel:
Lastly, in regards to flooring I am leaning towards vinyl because of its waterproofing as well as how thin it is to preserve headroom. I am using the book skoolie by will Sutherland as one of my main resources, however, in the book he recommends laying your flooring over the entire floor, and then framing in the walls and everything. That doesn’t really make sense to me, as then you wouldn’t be able to replace the flooring later on. My only concern with laying the vinyl after I frame is that in the kitchen, where water is a concern, there would be a small gap where the flooring meets the cabinets etc. for water to get into. Is this actually a concern? Could I caulk around where the floor meets the walls? Any other ideas if that small gap is a concern. Also, in case it impacts the answer I was planning on doing foam board insulation, then plywood subfloor, and then vinyl. Or if you recommend adding an additional layer into the flooring?
Thanks for all your recommendations and assistance
. Now for the other side
