filmphreaker
- Joined
- Feb 3, 2024
- Posts
- 3
Hello, can anyone tell me if there's a way to flush out my AT545 transmission fluid line without running the engine? Here's what's going on. I drained the fluid, changed the internal filter, reinstalled the pan and added new synthetic fluid to the pan. I then wanted to run the engine to get any old fluid out of the external lines of the transmission but the bus suddenly won't start. I've tried a ton of things to try to determine why it won't start but can't figure it out so I'm going to have to have it towed to a shop. I'd rather finish the transmission work before it goes to the shop if possible. Right now the return line is still disconnected and my next step was to run it to a new cooler I was installing. Such terrible timing for the engine to not want to start. It's some sort of electrical issue. 2001 International 3000 DT466e engine.
