Attaching studs to sheet metal
I'm thinking that I'll probably do a major remodel in less than 5 years (if I don't buy a new bus altogether). Right now it needs to be livable by late October. I'm thinking of spraying the floor and walls below the windows in bed-liner before framing and insulating in order to stop any potential leaks. Any other good ideas to keep water out? Silicone any seams?
I'm afraid that'll only seal water out of the living space and into the walls, likely with predictable (moldy, rusty) results inside the walls.
One thing that hasn't been directly mentioned regarding the insulation and interior skin is how the heat conducts. If the interior skin is left in place, I would expect the outer skin-ribs-inner skin assembly to have a near-zero insulating value. If the interior skin were removed and insulation built up from behind the exterior skin, I'd expect a better insulating result. I drew this sketch of a wall section to illustrate. I'm in cooling season right now so I used red to represent heat moving from outdoors toward the blue/cool indoors. The upper half represents a skin-rib-skin-insulation stack; the lower half a skin-rib-insulation stack. No calculations were involved in the construction of this theory... would anybody care to comment on it?
I remember doing some sort of calculation like this in a heat transfer or HVAC class in college. If I didn't sell that book back for beer money I'll have to look it up.
In the blazing heat of the day, I can not feel warmth on the ceiling anywhere but on the ribs, makes a lot of sense when you think about heat and cold transfer. Not a lot of heat, but I imagine it adds up over the length of the bus.
Brother you nailed it there. Currently I lack all of the above, but mostly time. I may gut the entire bus at some point, I just can't do it the "right way" right now. I may not ever be able to do a conversion like some of you pros do, as I do not have the skills, and collecting the tools would require me to slow down and stop - which defeats the purpose of my mobile lifestyle. My guess is there are more people like me out there than people that have the amazing skills you guys have.
This I can understand and respect.
Would anybody care to comment on it?
My findings are exactly as Family Wagon's illustration shows. The interior skin spreads the heat from the ribs like fins on a heat sink.
The interior skin at center from the ribs is almost as hot as it is right on top of the rib.
That is 1.5 inches of wasted space that could be used to insulate properly.
Mine will be no "prevost" either. A "prevost" would be useless to me and no good for my needs. I need mine to be beyond what a "prevost" could ever be.
I live in a shed built from 16 feet of a bus body. That is my quick solution without wasting materials building a bus quick that would never suit my future needs.
In my life, haste makes waste.
Nat
Thanks Nat, you summed it up well. We (or at least I) don't mean to say that leaving the skin in place is going to be absolutely disastrous and ruin all hope of insulating and achieving thermal comfort. But skipping the removal does waste 3 of the 87 (?) inches of total width, and removal of the skin also gives some weight savings and a good opportunity to inspect for exterior skin leaks.
So, I did some calculations this morning. Here are some of my observations:
1) Whatever you put between the metal ribs doesn’t really affect much. The metal ribs will conduct heat very well. Think of it like an electrical circuit: the metal rib is a short.
2) Slowing this heat transfer is all about what you put over the ribs. You have to sacrifice interior space in order to insulate better (or get rid of the metal ribs somehow).
3) Keeping the interior sheet metal doesn’t affect much because it is so thin.
Calculations; as in quantifiable number crunching? Care to share?
Incorrect.. The ribs are more thermally conductive than the rest of the wall and roof, bringing heat from the exterior to the interior, but they only make up 14% of the surface. In a typical bus the majority of the heat transfer will be through the other 86% of the roof, though the thermal transfer at the ribs will be most prominently noticed.
This is partially true. In between is also important. Maximum R-value is attained by insulating between the ribs and over them as much as makes sense for what you are trying to accomplish and your budget.
Incorrect. As Nat said, the interior sheet metal is a heat sink which is connected to an exterior heat sink by the ribs. The metal is thin, but it makes a big difference..
Seriously Austin, it sounds like your twisting the information to best suit what YOU want to do. If you were to stand in your bus in varying states of deconstruction, insulation and reconstruction you would have a very different opinion than what you stated above. Of course, you're welcome to do whatever you want, but some of us who have done the deed may have something valuable to say about it.
If you don't care about having the bus for a long time and want things done quick and dirty then go for it, but I'll tell you right now: insulating over the existing walls is an inferior solution. It'll work, but removing the inner walls, dealing with rust, sealing leaks and re-insulating results in a superior product with the best insulating qualities while retaining a decent wall-to-wall distance.
Incorrect.. The ribs are more thermally conductive than the rest of the wall and roof, bringing heat from the exterior to the interior, but they only make up 14% of the surface. In a typical bus the majority of the heat transfer will be through the other 76% of the roof, though the thermal transfer at the ribs will be most prominently noticed.
It honestly doesn't make a difference to me which is right, but I'm sincerely curious to see which way it works out. While in school I managed to dodge the thermodynamics class so many of my peers were required to take. At the time I thought myself lucky, but now I wish I understood it better!
It "seems obvious" (dangerous as that is!) that the ribs are so conductive that the air space between them might not make much difference. But the point is made that the length where those ribs exist is small compared to the length of the entire space, and I guess the question is whether so much heat can flow through that rib connection and the metal interior facing that what's in the air space between is irrelevant. In the illustration I made earlier I implicitly assumed this was the case by shading the whole wall cavity in red. That might have been incorrect.
We could estimate R value of the fiberglass and the conductivity of the steel, and figure out the surface area and thickness of the webs on the rib and so forth... but what about the thermal resistance of the joints between the rib and the two skins? I don't have any idea how to estimate that. I poked around online a little, and it seems the conductance of that kind of joint is highly variable. Is it reasonable to only consider the heat conducting through the webs of the rib vs through the fiberglass, completely ignoring the steel skin on both sides?
Haha.. whoops.. Did anyone notice my error? 14%+76% equals 90%. That was supposed to be 14% and 86%.
By the way, I get those numbers by saying that the ribs are 4" wide (in reality it's actually more like 2.5" because of the way they're formed) and the distance between is 25". That was a guess, but I've measured those spaces enough in my bus that I think it's pretty close.
I just corrected my previous post
IMO
We need someone with a inferred heat gun to take some real life shots.
I don't have a IR gun at this time. When I get one, I will run some numbers on the new 84 passenger that has not had the interior skin removed VS the 64 passenger that has been completely stripped to bare ribs and outer skin.
Both of my full buses are still yellow on the top. The short 8 foot section from the "Haul All" build is a light blue.
I would like to see pics of temp shots from the ribs, 1/4 the way to the center, and at center.
Readings from both before and after demo are welcome.
Even after the build is done, it would be interesting to see readings at various points on the completed ceiling.
So let's see what you all can come up with?
Nat
I just bought one and I live in a bus yard! Ive got my bus with 3" of spray foam on my celing, in addition to a slew of stock buses. If we get a sunny day out here, ill do it. The difference will be interesting. If it were me, Id take off the inner skins. It will only cost you a day of time and get you a lot more options. You could even recycle the steel for a few bucks. Thermally bridged steel inside the living space is going to seriously dininish the liveablity of you bus. I can promise you as I've experienced it.
R = L / kA
L is the same (2"). Area of the ribs is about 1/6th that of the insulation between the ribs (my calc used an even smaller area of 1/7th). k value of the metal ribs is over 1000 times greater for the metal than of the best insulation money can buy. And to top that off, it's a thermal circuit in parallel, so the equivalent R value is 1/((1/R.metal)+(1/R.insulation)).
L = 0.0508m; A.ribs=0.125m^2; A.insulation=0.875m^2; k.ribs=43W/mK; k.insulation=0.04W/mK;
R.ribs=0.0508/(43*0.125) = 0.0508/5.375 = 0.009 (K*(m^2))/W
R.insulation=0.0508/(0.04*0.875)=0.0508/0.035=1.451 (K*(m^2))/W
R.eq=1/((1/R.ribs)+(1/R.insulation))=1/((1/0.009)+(1/1.451))=1/(111.1+0.69)=1/111.8=0.009 (K*(m^2))/W)
Insulation between the ribs does virtually nothing.
R = L / kA
you missed convection.....
We're talking about the thermal qualities of the wall as a whole and how to deal with the situation.
Convection is another piece of the puzzle. Like any wall with a cavity and very little insulating qualities (or even fiberglass insulated wall cavities), convection comes into play.
Outside wall heats up, air circulates in dead space and transfers heat to inner wall.
Fourier knows...
Fourier knows...
For simplicity, let’s assume that there's only air between the panels (no moldy fiberglass to get in the way of that convection).
R.conv=1/hA
A=0.875m
h=10.45 - V + 10*sqrt(V)
That’s an easy empirical equation for calculating the convective heat transfer coefficient, but it’s only valid for 2m/s - 20m/s.
At 2m/s (nearly 5mph) the overall R value is reduced by about 15%. But I seriously doubt the air will be moving fast enough to make the convection significant. When that air isn’t moving there’s just conduction.
Also, the outside wall is being heated on the vertical edge. The bottom edge of the wall is cooler than the vertical side of the wall. It won't have the same effect as if the wall is being heated from the bottom (which would induce maximum convection).
