Back deck idea
In my mind I would think adding channels to the frame would be better than some contraption. Then no danger of anyone getting hurt raising an lowering or having it obstructing the emergency escape while driving.
Rear Deck
The guys at Van Life Conversions put this on the road recently.. (Jeff Flake)
Asheville, NC
Billy n NC
Well, that nicely solves the problem of seeing out the back ... by not caring that you can't see out the back. It's pretty funny that that's OP's exact idea brought to life (except for the direction of the boards, I guess).
Needs an umbrella.
It’s hard to tell from the photos, but some fail-safe locking mechanism that’s not a cable should be included.
Needs an umbrella.
Do you mean for the "up" or "down" position?
I'm sure the deck is pinned up -- it looks like the cable is flying loose in the up position.
It looks like there's a center support for the down position.
The cable itself is more than strong enough to hold the deck.
Personally, I want a ramp -- but if the ramp could also double as a deck looking as nice as this one that would be a huge party bonus!
FYI- a treated 12' x 5/4 x 6 board will weigh just under 14lbs. The same board in composite is almost twice as heavy at 27.5lbs.:ermm:
Almost 2x the weight as Marc pointed out.
They also require joists 12" OC instead of 16".
More eco friendly? I doubt it. Real wood is a very eco friendly material. It is a crop just like corn except that we harvest and replant every 30-40 years. Corn we get every year.
Pink bus deck: I think what is viewed as a support leg (in the up position) for use as the deck is a bike rack to haul bicycles. BUT I think 2 legs could/should be added as additional safety to just cables. ALSO, the deck looks like it is manually raised and lowered, pinned up, cables support deck lowered. I don't see reverse lights UNLESS they are incorporated into the brake/turn lights.
I think a hinged deck on the back of the bus is a great idea. You could do one like a toy hauler travel trailer/5th wheel using a winch of XXX capacity to raise and lower the deck to the ground for ramp use, raise from the ground for deck use, it could have adjustable legs to take pressure off the cables when set to deck height, it could have foldable or removeable rails for the perimeter, and a ladder or folding steps to reach the ground. A back up camera is almost a must/given. The deck for weight purposes could be made from new or reclaimed aluminum stadium bleacher seating. When up it should be pinned in place on both sides, have all the rear lighting for clearance, marker/parking/running lights, turn, brake, license plate, and reverse. OR the lighting for brake, turn, reverse, running lights could be cut into the bumper which would probably need to be moved back under the deck so it is flush with the deck when in the raised position.
So I have an idea, and I like to think that nearly everything has a solution... so give me your thoughts :surrender: @BlackJohn
I'd like to have a back deck on my bus as opposed to one on the roof so that my dog can hang out with me - I like to be outside, and I like to have her with me. (and I know I could bring a chair out onto the ground, but this is intriguing to me)
My thought is to have composite boards as a deck (I think they're lighter, and of course more eco) on the back of my bus with a winch to lower it level with the back door. I made (another) nifty image (I know, a very lame image), but hopefully it'll help me explain.
I realize I'll def need to have 1-2 boards that'll fold down/up to make sure the brake and turn signal lights are showing, plus I might want (or am required to?) have the windows exposed (even though I can't use them bc there will be walls in the way of my view?!)...
But that's why hinges were invented, right? Plus, I believe this would be more aerodynamic than a rooftop deck... better gas mileage but not the rooftop view... which might make it not worth it in the end. (I'm referring to boards 3, 5, and 7)
I'm just playing around with this idea... entertain me :whistling:
Two arms swing out to support tailgate/deck....removable in case it gets damaged. A little easier to repair on a bench. Lights built into tailgate.
On another note, two of my friends dogs didn't care for walking on the mesh/expanded metal...I guess it freaked them out seeing the ground. They came through the front of the bus and were exiting through the rear.
You could also visit a trailer mfg co. and see how they do the large tailgates used on toy hauler utility trailers....
