1964_Superior_Skoolie
- Joined
- Nov 29, 2006
- Posts
- 8
Has anyone ever connected a backup air compressor to an existing air brake system? I started up my bus again today and the air horn was going off again. I ran it for over 5 minutes at 2500 rpm so I think I still have a leak and the horn never went off. I fixed one but it still is leaking. So I need to find out where the other leaks are. I went ahead and purchased a 12v compressor that has a 100% duty cycle at 100 psi that I am going to use to trouble shoot the system. I will probably use the system to also inflate tires and other things once I install it. However, I was also thinking this could be a good backup system should the engine mounted compressor ever fail.
So my question is – has anyone ever performed an installation like this?
If I ever hook it up I would make sure it has an aux tank and a one way valve plus an overpressure valve for the tank.
Another advantage of having another tank would be that it would be easier to inflate any tires that need inflating plus it should be able to operate some air tools.
So if anyone ever hooked an emergency backup air compressor I would like to hear from you.
Thanks
Ken
Thanks
Ken
