bunedoggle
- Joined
- Feb 23, 2010
- Posts
- 97
Redbear said:bunedoggle said:I came across this place, a Yamaha factory dealer that sells units already converted to tri-fuel: gasoline, propane or natural gas. Hook up a hose and go!
http://www.yamaha-propane-natural-gas-generators.com/ They also apparently do not void the factory warrantee.
The Yamahas inverter units are slightly quieter than the Hondas, and have cast-iron sleeved cylinders for longevity.
It's not in my budget for spring, unless a new clutch for the wife's SUV is cheap, but I'm telling Santa Claus!![]()
My latest thinking for a generator is to combine a high output alternator with a 8HP Briggs and generate 12 Volts directly to charge my batteries. This will save me money on a battery charger, plus I save the inefficiency of converting from 110V AC to 12 V DC and back to 110V. I already have the engine and a 200 amp alternator is under $200.
If you add a car muffler to a Briggs or Tecumseh you can get it pretty quiet too. Plus you can repair the whole rig yourself with parts available anywhere.
