phillbus914
Can you feel the hoses on both sides of the valves? If one side is hot & the other is only warm or cool, than you probably have a clogged or stuck vavle. You could cut the lines on both sides of the valve and by-pass it with some rubber hose - which is most likley avaliable at a truck stop.
What is the temp gage on the dash reading? If it is low as well, maybe you have a stuck open t-stat on the engine - which would over cool the engine.
I live in Michigan and a lot of times in the winter, I see busses & big trucks with covers over the grill to block the air flow across the radiator. If the temp gage is reaing low, maybe try that (big piece of cardboard) But watch the temp gage if you do, you dont want to over heat the engine.
What kind of music does your band play? do you guys have a website?
Good luck
Good luck
