Sorry about the crap drawing. Trying to keep this super simple. Using pex and sharkbites. Am I missing any key components?View attachment 26726View attachment 26727
Yes, that helps. I was thinking about routing a line to fill the tank when hooked up. Good info for the check valves and hand valves. Thanks!A few suggestions.
On city water in a strainer and PRV pressure reducing valve is highly recommended.
A seperate water feed to fill the tank can be used off of the city water with a hand valve to control it.
Only one check valve on the leaving side of the pump is needed and one on the water heater entering side.
I like to install shutoff/hand valves on both side of each piece of equipment so that what water is in that piece is all that is lost when it has to be worked on.
Hope this helps
JD, so you only use the city water hook up to fill the tank, no gravity feed? I assume this is because that isn't filterable on the way in?
