KoehlerFarms
If a person decides that they want to go with a flushing toilet and black tank, is there any reason to use a cheap RV toilet instead of plumbing an actual residential toilet?
I installed the Dometic 210 and I’m pretty happy with it.
The rv toilets drain straight into the tank, whereas house toilets have a trap that seals the drain, which must be kept full of water.
The trap probably needs a lot more water to get the contents to move through it.
That said, a house toilet is so easy to clean. And are essentially free..I plan to try and modify one for the Nautibus.
A diamond cutting blade can cut the porcelain.
They also make high pressure kits so the toilet flushes with more pressure than just the weight of the water to push it through the trap. Those are the noisy kind you see at home depot, etc.
Pretty sure RV toilets were engineered because of the problems with large tanks of water sloshing/etc in motion...
I think the constant water supply was the bigger issue.
I've done several things to address those concerns:This ^ the rv toilet design that the waste discharge is straight down in to the tank is to reduce water consumption, in trying to wash that waste thru a conventional plumbing system you would use much more water. One of the biggest problems with rv toilets and our desire to conserve water is that whithout enough water in the tank you can and will develope the great tower of dry poop directly below the toilet drop. When this happens the unlucky rv tech gets to disconnect the plumbing and manually remove the blockage. Yes I have been that unlucky guy! The macerating toilet prevents that from happening (think of a garborator in your sink) without one all that food waste wouldn't get past the trap. An inline macerating pump will also allow you to install waste tanks on the passenger side of the vehicle and transfer that waste to a single discharge on the driver side.
Poop happens!![]()
Top shelf work JohnI've done several things to address those concerns:
1) Directly above the poo tank's exit to the dump valve I have a water inlet on the top of the tank that allows me to squirt shore water or grey water down onto any Mounds Of Doom that are growing there, and hopefully they will break them up before they become fossilized.
2) I have a transfer pump to move excess grey water into the poo tank (see above), and this will also keep more liquid in that tank to prevent any shitty stalagmites from rearing their ugly heads.
3) I also plan on having a water jetting wand in the bathroom next to the loo, then I can jet water straight down onto any Mounds Of Doom directly under the toilet's flapper valve.
By doing this I hope to gain the benefit of a low-flush toilet like my Dometic 310, yet still prevent Bad Things from happening inside the poo tank. I'm much more likely to fill up the 115-gallon grey tank than the 65-gallon poo tank, hence the transfer pump; when dumping the poo tank I'll probably first completely fill it with grey water so whatever is inside it will flow out with greater force, a veritable crap-tsunami.
Yeah, if we don't flush our tank regularly it really starts to stink. You need 3 holes in total for black and grey tanks imo:I was wondering why the previous owner installed a garden hose fitting on the side of the black tank.
