yippie-SKO
- Joined
- May 24, 2019
- Posts
- 17
First post! Sadly it's because we are currently having some issues with our 2006 International CE bus not starting. This has happened only once before and the batteries must be completely drained bc it won't even crack or light up the dash. I've come to two possible agents of our issue. The first being that our entrance door, like most IC buses, is air powered. Now that the conversion process has started, we go in and out of the bus manually opening the door all the time. I can hear the air being released every time we open and close it. I've read that there is a manual and automatic switch for the door and that if you keep it on automatic it could potentially drain your battery. The second possible cause is the VCR component. We have three cameras all wired to a control box and the box seemed to continue running (the fan in the control box) after I turned the bus off. Therefore, I completely unplugged the unit. Idk if either of those could be a plausible potential to our battery drain problem, so any feedback would be greatly appreciated.
Thanks,
yippie!
Thanks,
yippie!
