Well it finally happened, I was going to turn my bus on since it'd been cold and I hadn't worked on it in a while and the battery's drained.
I'm going to be installing a disconnect (any recommendations would be great, simpler the better)
I also need to get either a jumper or a charger, I'd prefer a jumper that I can carry with me in the bus for emergencies but if it's simply too big of an ask, then charger it is and I can always run that off a generator in emergencies.
I have a full size bus with an 8.3 ISC, currently has an array of 3 batteries. What range of amperage should I shoot for when shopping around for a jumper?
