nikitis
So I'm in need of doing my first battery replacement. I want to add a battery disconnect. I've read forums here to use the cole hersee 2000 AMP disconnect. Definitely going that route on the negative wire. I currently have a VPM issue where it's not powering on, and before going into that rabbit hole, I want to ensure batteries are top notch and in good condition. (Mine currently are not)
My questions are what are the best battery specs required for school busses? I want to go 3 batteries (Upgrade from 2). The reason I'm asking is because the current batteries I have literally have NO labels on them, or information melded into the plastic. They are straight up generic and I have no idea what kind of batteries they are other than the + and - melded into the plastic.
I plan to make my own cables, and want 3 in parallel with a disconnect. there's already additional wiring rigged onto the positive lines for auxilery items.
How many cold cranking amps do I need, AGM over STD? etc. Give me everything for a top of the line battery setup, and one for a budget grade battery setup that you would recommend. This bus will sit for awhile, but I plan to have a solar tender on them to keep them fresh with the battery disconnect as I do have always on drain issues. I understand all the stuff like letting it sit etc loses power over time etc, and I could just buy 3 large batteries and throw it in there, but I want to get a little scientific on this subject.
Bus is 1995 International 3800 Thomas 3-box.
I will add that most of the time I will not be in an extreme cold environment. Coldest it gets here is like 25 F.
Thanks in advance.
Thanks in advance.
