New Bus Network Gear
Since i do IT for work, when im traveling, i just want something that works, but give me lots of options. I have had T Mobile 5g home internet at my house as a backup WAN for my crappy xfinity service that has weekly outages. It has been okay, but i don't need it bad enough to mount an 4x4 mimo antenna on my house. When on the road, i plan to work 50% of the trip, so i need certain days with reliable internet. I want all my systems to work in motion, but also be able to improve them when parked. Since i had canabalized a light tower for the generator piece, i mounted a mast on my skoolie.
Well i got a 3rd party modem/router to permenently mount in the bus. It has tons of options, but what makes this one special is that it allows you to band lock or tower lock 5g and 4g connections. The modem that Tmobile sent me pretty much only allows wifi name and password setting changes. So after popping the sim into my new GL.iNet X3000 Spitz AX, i quadrupled any speeds i got from the T-Mobile gateway. I was also able to set carrier aggregation speeds to ensure i could balance upload and download speeds. Out of the box, i went from 220mbps to 860mbps. The upload on both devices was under 3mbps. That isnt ideal for remote work where i have VPN going. I changed a few settings that turned down download speeds to allow greater upload.
So since im a nerd, i got the settings i liked best for 5G and tested from the roof of the bus and then 20ft higher up on the mast.
Roof
Mast
Not a huge difference, but depending on the load of the T mobile towers, it can make a huge difference and allow uploads of over 180mbps. Additionally if im a longer way from the tower, the 20ft can make a huge difference. Especially clearing obstructions. Now, im not going to mount a $300 modem out in the elements, this was just to test whether its worth running cables and an antenna all the way up. If you think im a nerd for this, im sure my neighbors would agree with you.
So, like everything, gotta overkill it. At some point, ill also plop a starlink on the mast so that i can work from BLM and stuff with no tower nearby.
So one of the coolest things about the router is that it runs OPNSense OS, which i havent used in years and probably wont go into the poweruser settings, but the folks over at GL.iNet have built a really cool interface on top that allows all kinds of settings and features. The main one i wanted was to control failovers and internet connection priority. Currently, i have it set to prefer a WAN ethernet (Starlink) connection first, then the sim card, then any wifi connection i choose. It will then spit out the active internet to its wifi and ethernet ports. I looked at making my own pfsense device to do this, but the built in ability to choose wifi from a starbucks, or rest stop, etc and repeat that to all my devices made me abandon a home grown solution. Anyway, more to come on this as i build more, but for now, its just going to live on the dash while i continue the inside.
