SkyMaster
2007 Blue Bird Vision
- Joined
- Dec 31, 2023
- Posts
- 45
Of the eight ceiling speakers only two are working. I pulled the radio plate in the dash as well as the plate with the light switch's in an attempt to locate the speaker wires. No joy.
From the back of the radio only one of the four speaker outputs is connected to the INT\EXT wiring harness.
I pulled the plastic cover encapsulating the main wiring harness that runs down the drives side of the bus.
The wiring from the speakers to the main harness looks great and the main harness looks factory and appears to have never been opened.
The main harness runs down the pillar right behind the drivers seat to the electrical panel under the drives side window.
I could not find any wires in the electrical panel or in the radio cavity that correspond in color of wires used to connect the speakers.
I have the service manual and have downloaded all the wiring schematics from the Blue Bird portal and cant find anything relating to the speakers, there is a diagram for the radio but it does not include speaker wiring.
Has anyone run into a similar issue or found a wiring diagram for the sound system?
