musigenesis
I'm rebuilding a section of my floor, and since I don't completely trust my welding skills I'm going to be using nuts and bolts in a number of places in the new frame. I want to make sure these don't work themselves loose, but after researching this a bit, I'm unsure of the best way to do this.
Split-ring or toothed lock washers (according to some sources) don't work unless the material being bolted is softer than steel. Grainger has a big confusing section for lock washers: https://www.grainger.com/category/f...?attrs=Dia./Thread+Size|3/8"-24&filters=attrs and I'm not sure what would work best for me. Loctite is a possibility although I don't know how long-lasting that is. I was also thinking I could weld the nut to the bolt and the material, but I'm not really sure how well that works (can that compromise the strength of the bolt?).
Thoughts on how best to do this? I'm planning to generally use 3/8" Grade 8 bolts here.
