jazty
One more thing: battery companies make commercial batteries with calcium (??) which is supposed to be better for cold climates. That's what I have. I don't honestly know much about the calcium additive.. could be snake oil.
Why were you staying in your pickup? Were you at your workplace or somewhere you could keep it plugged in?That's a good point about keeping the batteries inside. Do you also keep your gray and black tanks inside to keep them from freezing?
I spent two winters in Alaska in a '80 F-250 Ranger pickup. I believe that was the last year the Ranger was a full size pickup. It was beyond miserable during the couple coldest months. There were a number of occasions I did not expect to wake up because I was so cold while going to sleep. Yeah, good times.
There are also devices that will let you send and receive text messages.Satellite phone if contact is that important, but expensive
are you talking about just having them close enough to use jumper cables or having something hardwired in the system?I think any Skoolie builder would be wise to consider designing their battery system so that the house batts can be used as back up starting power. Not that complicated and could save a tow or emergency call.
That's similar to what I do in the Army. Staying comfortable in a bus shouldn't be difficult if you have the right bedding and clothes. I can sleep like a baby on the ground outside in -30 degree weather with what's below:Be sure to bring a PSP with Parasite eve 2. That'll take at least a few days to completefun thread. One thing i have done to keep warm while sleeping is this;
I used to find leather couches in the alley. I would harvest the big sheet pf leather from the back of the couch. Two large leather sheets on top of my matress help keep the cold from coming through.
Now here is the trick i found that is a game changer - a sleeping bag inside of a sleepimg bag inside of a sleeping bag. When it was below 10 this month the water jugs froze solid it was so cold inside the bus at night, however i slept warm and cozy with only two fleece blankets on top of the tripple sleeping bag bed. At above 40 it actually gets too hot ! Lol
Oh and i sleep in a winter coat and hat with a thin cotton blanket over my face.
Feel so accomplished after surviving a cold stretch in the bus.
What did you use to stay warm besides lots of long underwear?
A related question that we've hit on a little bit:
What would you do to increase mobility if you're likely to be somewhere with lots of snow and ice? (Chains, shovel, a bag of kitty litter, etc etc.)
My bus has automatic chains and sanders. I'm hoping they work. Someone told me they are pretty simple and shouldn't be a problem. Knowledgeable local bus guy told me to ALSO carry chains for 2 of my rear drive wheels just in case because the automatic chains can get "kicked out" from under the tires in certain conditions on hills. If you may have to put chains on it's really nice to have a big piece of plastic to lay on while you are doing it.A related question that we've hit on a little bit:
