MadCompSci
I have a 2004 Thomas front-engine (Flat nose) bus with a Cat 3126 engine. The ammeter doesn't work (volt meter works fine), and when I put the ignition to the "run" position, like when waiting for the engine pre-heat to come up to temperature, the speedometer gently bounces between 5 and about 15 mph. When I start the engine the speedometer behaves normally.
Does anyone have any idea what is causing this?
