brake pedal "sticking" w/air brakes?
BA
baadpuppy
Guest
Just walked outside after moving my bus around the yard an hour or so ago and noticed the brake lights were on. When I checked, the air pressure was really low. I cranked up and the air wasn't coming up as fast as normal. I tapped on the brake pedal several times and heard the normal "whoosh" you hear with air brakes. Then I looked closer and realized the brake pedal wasn't at the same height as the air throttle pedal, so I reached down and pulled it up about 3/4" or so. After that the brake lights were out, and the air came up quickly.
Does anyone have a suggestion as to what might be causing this? Should I be doing some kind of PM work to the pedals? Should I just squirt the hinge with some lube and relax, or should I worry about this? I would really hate to have my brakes partially engaged while operating the vehicle.
Thanks,
jim
PS, I don't plan to move the bus out of the yard until I'm satisfied it will be safe.
My brake pedal does the same thing, ultimately I'd suggest replacing the pedal. In the meantime do what I do, squirt the hinges with WD-40, CRC or something similar and work the pedal up & down a bit and that should fix it up for now!
My bus I just got had angled wooden blocks on both the throttle and the brake - it probably made it easier to step on the brake giving you more leverage (the brake pedal is lower than the throttle) but I took the blocks off. I want maximum width of the pedals for my fat feet.
On the other hand, since most of the time on the highway is spent with the pedal most of the way to the floor, it might have been better to leave the block ON that pedal. Or not wear cowboy boots (the heel makes you have to hyperextend the toe).
Luckily, neither of the pedals were sagging due to extra weight of the blocks.... but I ripped them off anyway!
