Hi, the Broccoli bus is for sale!
We have all gotten older and bigger as a family and have moved to other priorities in life.
The bus is in Wichita, Kansas.
The numbers at a glance:
1998 Bluebird TC/2000 RE
~220k on the chassis
mississippi title
scale weight 33,000 lbs fully loaded, GRVW 36,500
300hp injector upgraded Cummins 8.3 12 valve engine (full mechanical engine)
in frame rebuild at AAA bus
MD3060 transmission
control model rebuilt
Regular ring and pinion, rebuilt
68 mph @ 1800 rpm
new michelin tires 2020, 3 years life remaining
aluminum wheels
upgraded front suspension
brakes, wheel bearings and suspension rebuilt 2019
gear reduction starter
2x diesel 5kw heaters
18000 btu dual head air conditioning heat pump
2600 watts of solar panels
14kwh battery pack
240 volt victron power system
4g cellular router/firewall and wifi system for remote monitoring
100 gallons fresh water
100 gallons gray water
reverse osmosis filter system
33 gallon propane tank
100 gallon fuel tank
30" shower
standard rv instant propane water heater
Natures head toilet
Interior is built out for a family of 6
Here's the tiny home tours video:
Here's the skoolie.net build thread from back in the day:
https://www.skoolie.net/forums/f11/the-broccoli-bus-9394.html
Here's an additional photo album of it over time:
Bus Sale
Setting expectations: the bus is mechanically awesome. but it's been parked for a year. I just went out and started it and moved it around the driveway. I would be confident driving it to it's next life.
When you buy this, be prepared to make it yours - which is code for "there's a lot of nerd/tech things in this rig that might not be appropriate for everyone" and means that you might want to simplify or re-do things in the rig.
If you have specific questions feel free to reach out here or dm, whatever the rules are.
Come pick it up and drive it away.
I am happy to coordinate showing it in person
Brake light warranty (when I no longer see the brake lights as it drives off, the warranty is up)
$55,000 USD
mississippi title
MD3060 transmission
68 mph @ 1800 rpm
aluminum wheels
14kwh battery pack
30" shower
Natures head toilet
Bus Sale
$55,000 USD
