Juicifer
After hearing what a pain it was for Justin, I was contemplating leaving the green rubber floor, and just putting the subfloor over it.
However, I had a little time to spend in the bus today, so I figured I would clean it up inside and maybe remove the metal trim rails on the floor. One thing led to another and I just started pulling it up...
Not a bad start but still a lot more to go. I will feel better when it's out.
All I used was a flat pry bar. For the next round I may try some heat.
Haha!! That's exactly how it happens and once you start, you just can't see yourself stopping. It sounds like it's coming up pretty easily for you. I bet if you try the heat, you won't regret it! But, seems like you're rocking through it anyway. You will not regret removing it.
Thanks for outlining your HVAC plans. Sounds like you've got every base covered for heat!! Your electrical work on that Volt battery is so, so over my head!!! I'm going to try and learn as much as I can from it as I follow along.
